1 - 10 of 10 Posts
Super Moderator
I had one of these. It sucked a reed valve after a couple of months and wasn't worth repairing.
There are enough bad reviews out there to make these a hit or miss proposition. If I wanted a 12v compressor with similar output I would spend the extra few dollars and get a Viair 88P - better built and far better customer service.
Currently $65.99 on Amazon Prime: https://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I
Viair website: 88P Portable Compressor | VIAIR
That being said, I think the best value for a 12v compressor with sufficient capacity to efficiently fill 32-33" tires (265/75R16 or 285/75R16) is the Viair 400P, currently $179 on Amazon but regularly on sale for about $150-160.
https://www.amazon.com/VIAIR-40043-400P-Portable-Compressor/dp/B000X9AXR8
I have the Viair 88P and it gets stupid hot airing up my 285s. It works, just be careful handling it for a few minutes after airing up.
Super Moderator
All of the 12v portable compressors get hot.
One concern with all 12v compressors is dissipation of the heat generated by compressing the air. I recall a thread on another forum for "hot rodding" the MV-50/MF-1050 compressors. There was a photo of the limited contact points between the cylinder sleeve and outer finned assembly. The author believed that insufficient contact between the sleeve and outer assembly contributed to the MV-50/MF-1050's inability to adequately dissipate heat which in turn contributed to the reported failures of those units. If a recall correctly, there was a photo of another brand compressor with better heat dissipation design. I've sometimes wondered if my Viair units feeling slightly hotter than my now defunct MF-1050 after filling up a set of tires had something to do with the Viar being better able to dissipate heat to the outer finned assembly than the MF-1050.
I own two Viair 400 series compressors - a 400P portable unit I carry in my Xerra and a 400H hard mounted under the hood of my jeep. For the hard mounted compressor I added a brass check valve at the cylinder head so that the piston will not have to start moving under pressure, thus reducing initial amp load, and I used a large brass "ell" that also serves as a heat sink to help carry heat away from the cylinder head. Does the extra brass as a heat sink matter? Who knows, but I like to think it does.
125293
BTW - One advantage of Viair compressors over those ubiquitous cheap chinese red compressors is standard 1/4" NPT thread. This allows one to use standard U.S. fittings to plumb the unit as desired or change over to standard air hose fittings and aftermarket hoses.
I have never liked those coiled plastic hoses and use a Flexzilla 1/4" x 25' hose with open flow chuck instead (shown with Viair 400P and DIY inflation/deflation tool):
125295
1 - 10 of 10 Posts
