1 - 6 of 6 Posts
Hi,
A couple of weeks ago I bought a new 2013 X (I'm just starting to use my 2nd tank of gas.) model which has no map light up front.
I've read the posts which cover the installation of a combination map light/sunglass holder.
My question is: If I'm able to obtain a standard map light, is the wiring for it in the headliner?
I'd appreciate it if anyone can shed some light (bad pun) on the subject.
It would be even better if someone has a map light gathering dust on a shelf.
Thanks
You will need to check for yourself. Sometimes the manufacturer will change things mid-build. Only way to be sure is to check your own vehicle.
Discussion Starter #4
Thanks for the replies.
I was hoping this would be as easy as the trailer hitch & wiring I'm presently doing.
If you get a map light of any kind don’t forget you will need the frame that goes above the headliner that holds it.
1 - 6 of 6 Posts
