I recently did a differential conversion from the c200 to the m226 and never got around to wiring up the e-locker. I am pretty new to the forum and I am not the best at wiring. I recently bought an Auxbeam switch panel and couldn't really find any write-ups on wiring to control panels from the locker. I found a write-up from the link below and I found the wiring diagram similar to what I would need just had questions about the differences in wiring to the control panel.
www.thenewx.org
Since I will not be using an OTRATTW Switch and will be using the Auxbeam, I was wondering if I need to run the blue wire directly to the control panel and then ground the grey, brown, and black wires, or is there another way of wiring.
How-to: Install Rear Axle and Wire Locker w/ Indicator...
Well, I installed my new Axle. I have a 2007 S model so this did not have the OEM locker set up. When I originally did my Titan Swap I changed out the C200 axle for an older M226. Over time I located an almost brand new (less than 1k miles, still has the factory stickers on it etc) M226 right...
