Ok, here's the deal.
I'm using spacers w/ my new wheels, not that it should matter.
I've taken my wheels of plenty of times now for working on my X and have had no problems. However, today I go out an try taking of a rear wheel. Two of the lug nuts are so tight--probably crossed-- that I end up snapping the lugs off. I try a front tire. Same thing; I snap two lugs off while trying to get the nuts off.
Now, I always put the lugs on as far as I can by hand so that I don't strip them. So, they were not stripped when I put them on.
What would cause them to be that tight or stripped by just being on the there? Did I over-tighten or under-tighten the lug nuts? To hot outside?
I didn't want to try the remaining tires at this point. Who knows what problem they have.
