You guys are going to need to swap your ABS cables.05XOR said:He's going to install the axles from my 2005 OR.
With wiring independent of the Xterra's cpu, he'll be able to lock the rear in 2wd and 4hi. Plus, he'll get better gearing.
As luck would have it, cornick is just a 3 hours away. How lucky is that.
Should be...lol but you never know!05XOR said:Thanks Koko. We're all over the ABS thing.
Now that cornick has done this already, it should be relatively easier the second time around.
