1 - 20 of 51 Posts
I'm finally getting around to posting pictures of my custom, homebuilt, one of a kind roof mounted light bar.
No noise. No vibrations. Solid as a rock.
nice. does the roof bin still open fully?
and x2 on those demisions/plans :)
Discussion Starter #17
Yes it has no effect on the wet bin. Thanks.
willgr1 said:
just my opinion, you should try to run the wires differently, going down the side of the windshield doesn't look very good.
I guess I could drill a hole thru the roof but I would rather see the harness then have a leak. I did loose some points at the last car show it was in.
RockyMtnX said:
Nice job, Gerdo! Simple, basic add-on. But man, that 1/2" steel is definitely overkill, lol! Is that just what you had laying around? Bet it is heavy. :geek:
It probably weighs 5lbs if that. No it isn't solid stock. It is a small "C" channel, 1/2"x2"x1/4". Good strength without the weight. It has been on the X for about 4 months and is holding up well, on road and off.
Maybe I should make/sell some.
what he said ^^^^
1 - 20 of 51 Posts
