1 - 11 of 11 Posts
Hi could some one please recommend a good 4" lift kit that is a reasonable price. It your be greatly appreciated.
Nothing cheap for 4" lifts. Calmini 5" or Titan swap.
Guess you could do a 2" spacer/AAL and a 2" body lift, that's around $500 I believe.
Are you doing it for looks or function? If it's looks, spacers/shackles/body lift will give you plenty of height on the cheap, though road comfort may suffer down the line (and a body lift is very time consuming). If you need articulation, Titan Swap it (if you can afford to). People harp on drop bracket lifts for many reasons - if you're doing it for looks, consider the added bulk of the (blue) hardware added to the underbody. Bigger tires will also add some height.
1 - 11 of 11 Posts
