S_e_X-Terra said:
why dont you just measure the middle of the front tire to the top of the front wheel well.... then measure the middle of the rear tire to the top of the rear wheel well.... if its two inches off... then you have your answer.....
but my guess is no!
Before my lift went in, I measured the gap that S_e_x is talking about.
Front: 19.5"
Rear: 20"
So, there is a .5" rake on the truck. If you lifted the front 2", you'd have a 1.5" rake, but your front would be sticking up higher than the back.
I measured this on my OR, and on a stock S, so I'm going to guess all trims are the same, if not very similar.
