1 - 13 of 13 Posts
· Registered
Happy Holidays everyone!
The forums have helped me many times for repairs and advice for mods. I got the NissTec Radflo Extended Travel Ultimate Kit a while back but haven't been able to get it install due to relocating for school.
Anyways, I finally have time to get it install so I was wondering if there are any shops around the Philadelphia area that can install aftermarket lift.
I live in an apt complex and have very little tools and space to carry out this modification.
I am also due for Front/Rear Diff oil, transfer case, Coolant flush change. I wondering if anyone had recommendation for mechanics/shop for maintenance work.
Of concern, I have noticed a clicking sound whenever I coast regardless of revving the engine, clutch engaged/disengaged. I am worried if my differential is damaged. I looked up on the forums and it looked like my drivetrain may be the culprit. :confused:
Sorry for the long post. :blob7:
TL;DR - in need of installing lift kit, drivetrain fluid change, and diagnose clicking sound
:lurk:
· Premium Member
I am located in Roxborough, Philadelphia, PA.
Sent from my LG-H830 using Tapatalk
If you are on Facebook, please search for my club, GPAX - Greater Pennsylvania Area Xterras. We can add you to the group and organize a day to install your lift.
www.gpaxterras.org
· Registered
· Registered
Discussion Starter · #10 ·
Just an update, Got my Front, rear, transfer case, transmission oil changed yesterday and the clicking noise still remains. Looks like it the U-joint is the culprit. Will keep you guys posted.
· Registered
I’m in Oxford area and have a 3 bay garage if you need help. I installed a PRG lift on my truck a couple years ago.
Where are you originally from? If you’ve been in the salt belt for a couple years, I’d suggest buying new LCAs. You may end up with seized bolts in the LCA which requires you to cut them out.
· Registered
Discussion Starter · #12 ·
Hey! Thanks so much for the offer! My car is originally from CA but moved to PA in 2015. I guess I can buy a pair of LCA for precaution and return them if they're not needed. Any brand recommendations?
· Registered
Best suggestion is try to spin the bolts on the LCA’s prior to purchasing anything. If they rotate, there’s a good chance you’ll be able to get them out. You do not have to loosen them for this.
I always try to buy OEM where and when I can. There’s a reason their parts last as long as they do. I have heard good things about quite a few brands on Rockauto, but I cannot recall their names right now. Do a quick search on the forum for reviews on LCAs.
1 - 13 of 13 Posts
