1 - 5 of 5 Posts
Hey there!
I installed some LED lighting all the way around and its AWESOME!! (2011 NISSAN PRO-4X) however Im getting hyperflash on the front and rear. I dont want to wire in load resistors and heard that you can change out the flash relay? Anyone know how to do this and where to snap one up?...
LASFIT has some bulbs that have the load resistors built in but they are wayyyy on backorder
Thanks,
Kevin in NH
No way to change the flash relay on these trucks. Either use bulbs with a resistor pre-installed to mimic the amperage draw the system expects, or wire in a load resistor. I usually do the latter and it works fine.
Sent from my Pixel XL using Tapatalk
1 - 5 of 5 Posts
