That is what the back hatch is for!Offroad said:That would work great on pretty narrow trails where you can't fully open the door...![]()
MC - Where are you - Look its got gas struts and everything. . . . .Muzikman said:MC, that has you written all over it.![]()
You would still need someone to open the hatch for you. I wish there was a hatch release on the inside, it would make it easy to crawl out of the back when you sleep in the X, rather than having to go out of a door.Lyrex said:That is what the back hatch is for!Offroad said:That would work great on pretty narrow trails where you can't fully open the door...![]()
buxwheat said:You would still need someone to open the hatch for you. I wish there was a hatch release on the inside, it would make it easy to crawl out of the back when you sleep in the X, rather than having to go out of a door.Lyrex said:That is what the back hatch is for!Offroad said:That would work great on pretty narrow trails where you can't fully open the door...![]()
I've thought of that too. You can see from the photos in my Lift Gate Leak thread that it wouldn't be too hard to come up with something. The idea I had when looking at the 'guts' of the liftgate was a piece of wire with a ring on the end, to make a simple mechanical release, to do the same thing that happens when the exterior handle is used.buxwheat said:I wish there was a hatch release on the inside, it would make it easy to crawl out of the back when you sleep in the X, rather than having to go out of a door.
if you want to go the fancy route, you can buy a trunk release solenoid and mount a button somewhere.dpatton said:I've thought of that too. You can see from the photos in my Lift Gate Leak thread that it wouldn't be too hard to come up with something. The idea I had when looking at the 'guts' of the liftgate was a piece of wire with a ring on the end, to make a simple mechanical release, to do the same thing that happens when the exterior handle is used.buxwheat said:I wish there was a hatch release on the inside, it would make it easy to crawl out of the back when you sleep in the X, rather than having to go out of a door.
I swear I have seen a "How To" on this somewhere. Time to go looking.......buxwheat said:I wish there was a hatch release on the inside, it would make it easy to crawl out of the back when you sleep in the X, rather than having to go out of a door.
