Intro Comments: This is a daily driver turned overlander. I’ll start adding past progress and mod install pictures over time. Since I still use it for work and have a large dog, the back needs to be empty or easily cleared at a moment's notice. Permanent fridge, drawer, sleep, or kitchen setups are pretty much out of the question. Clean mounting solutions for my gear continues to be a top priority.
Year: 2015
Trim: X
Color: Night Armor
Suspension + Lift:
ADO 2" Bilstein 5100 Lift Kit + AAL
Wheels + Tires:
Looking for a spot for some long range shooting out on BLM land.
Mall crawling.
First multi-day trip with the X on the Mojave Road.
Installed the ARB compressor the night before.
Mojave/Death Valley trip.
Taken shortly after buying it.
This forum really helped me get to this point so I hope I can give back a little in documenting my progress and installs. Thanks for reading.
Year: 2015
Trim: X
Color: Night Armor
Suspension + Lift:
- Front
- Bilstein 5100 (set at 0)
- ADO D40-F-M coils (about 2" of lift)
- ADO 1/2" spacer
- ADO High Clearance UCAs
- Rear
- Bilstein 5125 (3-4")
- ADO Parabolic Leaf Pack (about 2" of lift)
- 2.5° axle shim
- ADO Recessed ubolt plate
- Timbren Active Off-Road Bumpstops + 1" extension
- Z1 adjustable lift shackles (1.5" of lift)
- Mikellis 2” body lift
- Rear sway bar deleted
- Rear brake line extension bracket
Wheels + Tires:
- Pro Comp 89 Series Kore 17x8”
- BFG KO2 285/75/17
Pro Comp 285/70/R17 AT Sport- Gorilla Automotive lug nuts
- Melt mod + fender trim
- XTP Intake Manifold Spacer
- AEM Dryflow air filter
- Airflow Snorkel + Sy-Clone 9001 Precleaner
- ARB C200K rear air locker
- Rear diff breather relocator 7’ hose
- Ballistic Fab C200K rear diff cover
- Pro-4X Skids
- roXterra Slim Roof Rack
- 2x Pelican Vault V770 cases
2x Pelican Air 1535 cases- Trail'd gas container (mounted in factory spare location)
- Midnight Forest 2 gal Rain Basin water tank + hose kit
- Southco locking wet box handle
- OVS awning w/ muffler clamp mount
- OVS shower curtain w/ quick release mount (stowed in roof box when not in use)
- Front bumper chopped
- Habitat Off Road front recovery points
- Balmer Fab rear bumper
- AVS window vent visors
- Gobi ladder
- Nissan Murano rear wiper blade swap
- Mudflaps deleted
- Cover King front seat covers
- Console Vault
- Raingler barrier net behind front seats
- Fire extinguishers mounted
- Orange Boxx Fab Rear MOLLE Panels
- OEM ceiling cargo hooks added
- Shovel mounted inside hatch w/ Quik Fists
- Pelican iM2050 Storm Case to replace OEM first aid kit
- Husky liners
- OEM cargo tie downs added
- Gorilla Offroad gas hood struts
- McMaster-Carr gas hatch struts 18.19” extended length 150lbs
- Rear seat bottoms deleted
- Optima Yellowtop D34 battery
- 20” Nilight LED lightbar
- 2x Rear Amazon LED light pods
- LED marker lights (front, rear)
- Diode Dynamics LED interior lights
- Pioneer head unit
- Garmin Overlander
- Garmin BC 35 cam (front and rear)
- Amazon backup cam (redundant)
- Garmin Mini Dash Cam
- Garmin inReach Mini
- weBoost OTR cell signal booster
- Cobra 19 Mini CB radio
- ARB CKMA12 OBA
- ARB tire fill-up hose kit
- Indeflate Twin Hose Unit
- Toyota OEM Land Cruiser jack w/ SafeJack cradle
Unijack- Tire puncture kit
- Tool bag
- 12v repair kit
- Jumper cables + jump starter
- Spare nuts, bolts, washers, fasteners
- Maxtrax Mini + Jack Base combo (stored in wet box)
- Short spade
- Yankum 7/8” Kinetic Rope 20’
- Yankum 3/8” soft shackle
- ARB long soft shackle
- Tow strap
- Factor 55 Hitchlink 2.0
- Tarp
- Weathertech double sided reflective window screen full set
- Skeeter Beater bug nets
- Dometic 20L cooler
Shrockworks sliders w/ full step on order- Hefty aluminum bumper on order
- White Knuckle sliders?
- GMRS radio to replace outdated CB
- Regear?
T-swap? - Rear quarter window gull wings?
Mall crawling.
