1 - 20 of 39 Posts
Banned
Username: knightrider
Real Name: Jordan
Year: 2012
Trim: Pro-4X
Color: Knight Armor
Transmission: 6 Speed Manual
Purchased: July 4, 2012
Factory Options:
-Pro-4x Pkg with M226 E-Locker Rear Axle
-3.69 Gear Ratio
-Rockford Fosgate 380watt Sound system
-MaXterra rear bumper with tire carrier, cb antenna tab, flush hitch, and LED reverse lights
-Shrockworks engine, trans and tcase Skidplates
-WhiteKnuckle rock sliders with DOM rubrail with kickout
-Hefty Fabworks Zombie Edition front bumper
-Hefty Fabworks radiator skid
Communication:
-Uniden PRO520XL CB
-Firestik ll 5' antenna
-Yeasu FTM-350AR 2m/1.25m/70cm ham radio
-Diamond NR-770HBNMO antenna mounted on rear door with Diamond K400C/NMO lip mount
Engine:
-Nissan 4.0 DOHC V6
-Volant Intake with AEM Dryflow filter with sand sock
-Bully Dog GT Tuner -Premium gas, WOT restricter removed, +2 timing
-XTP Intake Manifold Spacer
-Clutch Pedal adjusted
-Pioneer AVH-X8500BHS DVD Receiver
-SiriusXM receiver
-Bluetooth OBDll Dongle
-Rear Cargo outdoor carpet mat
-8 Gal Action Packers
-400w inverter
Lighting and Exterior:
-Morimoto H1 Projectors retrofitted into headlights
-Morimoto XB35 4300k HID with Morimoto 3five ballasts
-Fog light bypass,
-Led interior lighting, Red for camping, white for everyday
-LED Reverse lights in MaxTerra bumper and taillights
-LED brake lights in stock housings
-GhostRack(Xoskel) full replacement roof rack
-20" single row LED bar for front bumper
-5x KC HiLiTES Pro-Sport 6" HID Spot
-CVT Mt. Shasta Stargazer RTT
OBA:
-Air Zenith OB2 Compressor
-5 Gal 200psi aluminum tank
-Front and rear quick disconnects
-inline moisture collector
-25 ft coiled hose
-2 tire fill setup with 200 psi digital gauge
Recovery and Emergency Gear:
-48" Hi-Lift eXtreme
-2"x30' strap
-Recon 10,500lb winch with synthetic line
-8x Koch 8T Straight Pin 7/8 shackles
-DeadMan Offroad Earth Anchor
-Fire Extinguisher
-Fully Stocked first aid kit
-2x 4Gal Rotopax gas can
Suspension and Axles:
-PRG Titan UCA, Radflo 2.5" Coilovers w/ 700lb springs and 1.5" lift spacers
-Doorman titan LCA
-PRG extended brake lines
-Nisstec extended axles
-Moog Titan tierods
-Alcan leaf springs +600 lb 3" lift
-PRG adj. shackles low hole
-Bilstein 5165 10" travel Remote res shocks
-Factory E-Locker bypass for operation in 2hi and 4hi
-4.56 Gears
Wheels and Tires:
-KMC XD Addict 2 17x9 +18 offset
-Goodyear Duratrac 315/70R17
Mods On Order:
Mods to Complete:
-backup camera
-ARB M205 locker
-4.56 Gears
Parts Removed:
Stock mudflaps
Rear Swaybar
Front Swaybar
PRG Xterra UCA
55w HID installed in factory roof lights with custom glare shields
Puma 3/4HP 120PSI 12v compressor
PRG AAL
Eibach 600lb springs
radflo 2.0 remote res shocks
-255/85/16 BFGoodrich KM2 on stock Pro-4x wheels
-1.5" spacers on rear
Comments:
After owning my 2001 Xterra for 2 years and pouring lots of money into it, I decided to purchase a new Xterra. The search seemed to end before it even started after seeing a Lava Red Pro-4x at my local dealer, but it was a automatic.
After tracking down another dealer 45 mins away with a Lava red that they claimed was manual only to find out it was automatic as well, I traveled another hour away to find my night armor Pro-4x manual on fourth of July. Proceeds from my 2001 will be used for mods on my new rig. much fun to come.
Recent Pictures:
315/70r17 duratracs on KMC XD Addict 2 17x9 +18
They don't stick out too far.
Banned
They are cheap ones off ebay, xentec. http://pages.ebay.com/link/?nav=item.view&id=270950198976 They were $35 and plug and play to the 9005 bulbs. I wanted to compare the output and pattern to my roommates stock lights. I will have to try and get comparison shot but I can tell you they are by far the best and cheapest mod you can do for great light in the stock off road lights. I'm planning on upgrading my headlights with a retrofit I saw here as well.
Banned
Discussion Starter · #8 · (Edited)
Yep, I saw a write up someone else did on here but its real easy. Just remove the stock bulbs, insert the 9005 hid bulbs, plug the ballast to the hid bulb and plug the stock wires that went to the halogen bulb into the ballast. I secured the ballast to the gray support that goes across the air dam with double sided tape that came with the kit and zipties for insurance.
Edit: here's the write up http://www.thenewx.org/forum/showthread.php?t=29520
night armor rules! :drink:
just picked mine up saturday. it was between bright silver or night armor.
1 - 20 of 39 Posts
