Close Up Pics...
Here are the close up pics of the tires...
Here is one with the tires straight, there is about an inch and a half between the tire and the plastic:
Here is one of the area you need to heat up and bend in, its hard to picture but just go look at the plastic area outlined and you'll see what needs to go in. this is also with the wheels turned allthe way to the left and there is plenty of clearance:
This one is with the wheels turned about half way, this is at its closest point to the plastic, with a little less than an inch between:
This is one with the wheels turned all the way to the right (from the driver side) and the is plent of clearance in the front and the back, the pic is of the backside:
Here is one of the front when the wheels are stright:
This is one of the passenger side, wheels straight, about an inch and a half clearance:
Another of the passenger side inside the wheel well:
Here is one of the entire... tire:
this last one is of the tire size:
