Where will you lift the vehicle with the HiLift jack from?
I have the hooks to lift it from the wheels. I had it handy so figured I'd throw it in the X just in case.Where will you lift the vehicle with the HiLift jack from?
I plan to get sliders, probably this year sometime. As I said, I'm just getting things going with this setup. I also need to actually get some shackles etc since I finally got the bumper installed.How would you use a Hi-Lift with wheel adapter to change a tire?
Get some sliders and a tube adapter for your Hi-Lift so you can lift from the sides independent of the wheels. You need the sliders anyway.
You can use a shackle in one of the recovery tabs on you RockyMtnX front winch mount to lift from the front. Same for the rear if you have a receiver hitch and receiver shackle bracket.
