1 - 20 of 412 Posts
Intro Comments: This WAS my daily driver, I drive over 70 miles every day and I also frequently tow a 4,000 lb boat. I've tried to balance good road handling characteristics, improved towing, and good off road performance without killing my MPG too much. Now it is my toy, primarily used for offroading, with some towing thrown in the mix.
Username: jsexton
Xterra's Nickname: "My X"
Year: 2007
Color: Avalanche White
Transmission: 5AutoTrans
Drive: 4x4
- PRG Titan UCA's
- Dorman Titan LCA's
- Hitachi Titan Tie Rod Ends
- Titan Booster and MC
- Tundra Bilstein 5100's with custom top hats
- OME Tacoma coil springs
- Nisstec cam bolts
- Alcan 4" + 600 LB leaf springs
- Bilstein Rear Shocks w/ custom mounts
- PRG Adjustable Shackles
- 315/75r16 Nitto Trail Grapplers mounted on stock 2012 S wheels (6)
- 2" Bora Wheel Spacers on rear axle
Engine/Drivetrain:
- 2014 VQ40
- M205 w/4.56 gears and ARB Air Locker
- M226 w/4.56 gears and ARB Air Locker
- OEM Titan Front Axle Shafts/CV'S
- Koyorad A2807 Radiator
- 350z 170* Thermostat - Nissan P/N 21200-4w01b
- Offroad Gorilla Silicone Hoses
- Rear diff breather mod
- XTP IMS (Did not re-install onto new engine)
- Radiator bypass with 2nd Transmission cooler - No SMOD for me!!! (Un-bypassed with new rad)
- Femco oil drain valve - No-Spill Systems P/N 15-12125-01
- Rebuilt Transmission
- Homemade Quick Detach Sliders (Removed)
- White Knuckle 2" BL lift sliders with DOM
- Homemade rear tire carrier/winch bumper
- Homemade Radiator Skid
- ARB Diff Cover
- Hefty Fab Skids
- Hardcore offroad plate bumper
- Blacked out badges
- Heated Mirrors in OEM mirrors
- Tow Mirrors - made quick disconnect harness so I can quickly swap between stock and tow mirrors (only use tow mirrors on fishing vacations)
- Added OEM Fog Lights
- Added OEM Body Side Molding
- Bosh Icon front wipers
- 16" rear wiper blade and rear wiper spring mod
- Melt Mod
- Removed side steps and mud flaps
- Removed Viggs hood blackout - just not for me
- RockyMtnX Front Recovery Brackets
- Gas Strut Hood Rods from OffroadGorilla
- Homemade Hi-Lift mount for roof rack - pics of it mounted here
- 2" Nisstec Body Lift
- ARB CKMA 12 Onboard Air Compressor
- Kenwood Excelon head unit
- Weathertech Floor Liners (Front)
- McMaster Rear Hatch Struts - 175 lb Should have gone with 150 lb. On the bright side, the hatch still flies up 3 years later in -15* F temps.
- Universal Bedmat version of "Rex rug"
- Heavy Duty D-rings for cargo area
- Truck tool kit w/ Craftsman under seat boxes
- Uniden Pro520XL CB
- Firestik II 2' Antenna
- DIY onboard co2 system (not for every day carry)
- Homemade "half rack" for the cargo area
Recovery Gear:
- Smittybilt x2o 10k comp winches (2)
- 3/4" Shackles (4)
- Warn 3"x30' snach strap (2)
- 3" Tree Strap
- Snatch Block
- TRED 1100 Recovery Tracks (4)
- 60" Hi-Lift Xtreme
- Receiver Shackle
Preventative Maintenance:
- Radiator bypass with 2nd transmission cooler
- Poor man's transmission flush every 20-30k
- Synthetic oil & filter changes every 5k
- Air filter every 10k
- Diff & T-case fluids every 30k
- Moog inner and outer tie rod ends (lasted 30k miles, switched to hitachi)
- Timken wheel bearings - both in front
- NGK IR spark plugs @100k
Removed:
- Radflo OEM length coilovers with 600 lb springs (will make them extended length when I rebuild them)
- Custom 1" thick top plate spacer (~2" lift)
- SPC UCA's
- Moog LCA's
- OME LT/MED CS061R Leaf pack - Added the OME D37XL HD leaf to convert this to a HD pack
- Bilstein 0-2" 5100 rear shocks - these top out at the same time the leafs fully extend
- 265/75R16 Firestone Destination AT's with 1.25" Bora Spacers on Stock Wheels (Removed/Replaced)
- 285/75R16 Nitto Terra Grapplers on 16x8.5 MB TKO's
- R180 w/3.54 gears from 2009 manual frontier
- lokka
- Hefty Fab Tube Bumper
- Hefty Fab Radiator Skid
- Hardcore Offroad Radiator Skid
- PRG Aluminum Diff Cover
- Removed front sway bar
- Removed rear sway bar
Future mods:
- custom roof rack
As she sits now:
Early on - After I installed BSM:
Got sick of things sliding around in the back of the X so i ordered a universal bed mat and trimmed it to fit. I made a large one for when the seats are folded down and a small one for when the seats are up. These things have a lot of grip and will definitely solve the problem.
Installed Nisstec Radflo OE lift with OME rear leaf springs. It rides fantastic... i couldn't be happier!
Before (33.5" at front fender, 33.5" at rear fender w/ 265/70R16 tires)
During
After (35" at front fender, 35.75" at rear fender w/ 265/70R16 tires)
Added towing mirrors. They do not look near as goofy in person as i thought they would.
More info/pics here: Second Generation Nissan Xterra Forums (2005+) - View Single Post - Awesome Find ... Xterra Towing Mirrors
Removed side steps, and front mud flaps (forgot to remove the rears while I had the wheels off - I'll do that next weekend)
Installed extra leaf to make my OME Medium leaf packs HD leaf packs, 1.25" Bora wheel spacers. Firestone Destination AT 265/75R16
Flexidip on the hood
New wheels and tires (Nitto Terra Grappler 285/75R16 on MB TKO's). Why in the world didn't I do this the first time???
Melt mod.
Yes, that's a softball - worked perfect
Installed Nisstec 1" top plate spacer, SPC UCA's and got my home made quick detach sliders mounted up.
More info here:
Quick Detach Slider/Steps Build - Second Generation Nissan Xterra Forums (2005+)
Installed PRG Diff cover
All buttoned up - put some fuel line on the brake line because it was pressed against the cover. I definitely don't want that rubbing through.
Skids Installed
Built a rear winch bumper
Hefty fabworks tube bumper & Smittybilt x2o comp winch
Discussion Starter · #11 ·
Thanks guys. It sounds funny, but those mats are one of the best mods I've done. Nothing slides around at all any more. That drove me crazy
Where did you get the universal bed mat? I've looked on Amazon and Ebay and they're damn expensive.. like $80, yikes!
Going to try Home Depot for cheaper material.
Discussion Starter · #16 ·
jsexton's Daily Driver
I bought it on Amazon for about $80 shipped. This is way better than the weather tech cargo liner. It does not slide at all and nothing slides on it. I used to have a carpet mat like you buy at HD and that sucked too imo. I discovered bed mats with my last pickup - I'll always run them from now on, pickup or suv, bedlined or not.
For me the point is not to protect the interior, but to keep things from sliding around.
How did you make the template? I need to make one of these for my dogs.
Discussion Starter · #20 ·
1 - 20 of 412 Posts
