[+] TS Radflo 2.0 w/ 650springs
[+] Titan m205 3 rib w/ 3.36 gearing.
[+] PRG Titan UCA
[+] OEM TItan LCA
[+] Hitachi Titan Inner/Outer tie rods
[+] Nisstec Camber bolts
[+] Alcan +3" with +550lbs over stock
[+] Bilstein 5100 Rear 2.5-4" Shocks
[+] Timbren Rear Active Offroad bumpstops
[+] Superbump Front bumpstops
[+] PRG Red Shackles
[X] NissTec 2" Spacer/AAL Kit
[X] MK84 Front Coilovers with 650lb red springs
[X] SPC UCA with greaseable ball joints
[X] Moog LCA
[X] OME Dakar HD Leaf Packs
[X] Rear Sway Bar
[X] Front Sway Bar
[$] Nisstec 1" Spacer
Engine/Exhaust/Drivetrain:
[+] Rear differential breather valve relocate
[+] AEM Dryflow 28-20286
[$] Intake Manifold Spacer
[$] Volant Air Intake
[$] Airflow Snorkel
[] M205 Front Diff with ARB Front Locker. Currently have a new 3Rib 2017 m205
[$] 4.10 Gears
[+] Hefty Steel Engine Skid
[+] Hefty Aluminum Transmission Skid
[+] Hardcore Offroad Full Grille Guard front bumper
[+] Stock P4X skids elsewhere
[+] ShrockRocks Sliders with Textured Black Powdercoat
[$] Hefty Aluminum Transfer/Gas Skids
[+] Hardcore Offroad Steel Radiator skid
[+] maXTERRA Rear Tire Carrier with Jerry can holder with added FrontRunner Drop Down Table
[+] Nisstec Rear Shock Skids - Red
[+] Offroad Gorilla m226 Diff Skid
[X] Remove OEM Mudflaps
[+] Painted all plastics black for stealth look
[+] Front Window Tint 50%
[+] Por15'ed the entire underbody for rust protection
[+] Locking roof gear box - Southco 92-21-511 T-handle
[X] Auxbeam X-series 22" Lightbar
[+] KCHilites 6" Black Daylighters LED 40w
[+] MaxTerra projector rear backup light bulbs
[+] Diode Dynamics LUXEON LED Fog Lamps w/ yellow Lamin-X film
[+] Low Profile Roof rack crossbars aka Unistrut mod holding my FSR M49 RTT
[+] Trico ExactFit 16B rear wiper mod with stronger spring.
[+] Raingler Large Ceiling net holding sleeping bag, blanket, clothes, poncho etc.
[+] ZheKing interior LED light kit
Recovery/Comms:
[+] VIAIR 300p Portable Compressor
[+] 20' 15,000lb Tow Strap
[+] 8' TGL Tree Saver
[+] 2x TGL Axle Straps
[+] TGL Snatchblock 24k lb
[+] 2x Vault Shackles
[+] Baofeng UV-82 Radio
[+] Cobra ACXT1035 GMRS/FRS
[+] ICOM 5021 HAM radio with Tram Antenna
[+] Midland 822 CB mounted with MPS mount w/ 3' Firestik II antennae mounted on Diamond K400 Hatch mount
[+] 3ton All-in-jack
[+] USGI E-Tool
[+] Gerber Combo Axe/Saw
[+] Fiskars Chopping Axe mounted on roof rack
[+] Bond short shovel mounted on roof rack
[+] Silky GomBoy saw
[+] TRED 1100's
[+] Ipad navigation 67designs setup using center bin
[+] Smittybilt X20 10,000 synthetic winch
Other:
[+] 8Gal Action Packer loaded with SocketSet/JBWeld/Fluids/ etc.
[+] 8Gal Action Packer with various camping supplies including sleeping supplies, energy bars, fixed blade, cooking set, water purification, fire starting etc.
[+] Soft Cooler loaded with water
[+] Tool Roll loaded with various tools
[+] Various First Aid and Trauma kits for different levels of injury.
[+] BoulderTools Auto-tire deflaters
[+] BoulderTools Deluxe Tire Repair kit
[+] eBay red engine struts
[+] Advance Auto Platinum AGM 24F
[+] ARB 50qt Fridge
[+] Noco 4amp on board battery charger
[+] Freespirit Recreation M49 RTT
Well a few things have happened since my last update. I've ordered a Hardcore Offroad Full guard front bumper due to be finished in 2 weeks and got a Smittybilt X20 10k synthetic winch ready to put in it.. Got my Shrock sliders installed, made a RAM mount for my iPad for navigation, ordered a Hefty aluminum transmission skid and got a Midland 822 CB mounted in the cab (got an external setup coming in tomorrow to finish it).
What do you think of these lights? Youve had them in for a few months now. Any flickering? Good quality? I see them on Amazon for $14.99. I've been wanting to upgrade mine for a couple years. I originally had my eyes on a pair from DiodeDynamics, their most powerful 921 bulbs. But couldn't get myself to drop $90 on them.
Held up fine so far and I still love them. Nice and bright. At their price you can't go wrong imo. I like you also considered the DD ones but likewise couldn't justify the $$ on a couple leds.
I used a green brilo pad to rough up the plastic and cleaned them with rubbing alcohol then sprayed 3 coatings of Adhesion Promotor followed by 3 coatings of Rustoleum Trim and Bumper Paint in Matte Black. On the side trim, grille and door handles I instead used Rustoleum Acrylic Enamel Auto Semi-gloss black which from my experience isn't really that much more glossy but is a deeper color black than the T&B. Either is fine.
The steel portion of the rear bumper I sanded down, cleaned with rubbing alcohol then used 3 coats of Rustoleum Self-Etching Primer followed by 3 coats of Rustoleum Acrylic Enable Semi-Gloss. The step that attaches to the bumper I bedlined instead of paint.
What I have left on here has been fine so far except for the scratches that happen due to tree limbs scraping me while I wheel. Prep work is king.
Right on lol. It's been lonely here in SWVA :grin: Thanks.
Few updates planned come warm weather too:
M205swap in with Pathfinder axles unless I get some big change to go full Titan swap lol
Maxterra rear bumper w/ Jerry can holder ordered ETA around March
Gonna be cutting my fenders to open them up for wheel spacers until the full swap happens.
I'm be sanding/por15/Raptorlining around the fenders and side that falls in line with the rear plastic panel. Similar to how Chris did his.
Well my plastics aren't gray anymore :wink: so I was thinking black.
Edit: I suppose my stock roof rack is still grayish but hopefully that's coming off this year as well.
If I had a second vehicle to keep the X down for a week or so I would take everything off, sand it and then Raptor Line it in tan with the side trim piece and below being black Raptor.
Similar to how this 4Runner was done. I like that effect quite a bit. I'm not really a fan of black that's the only part I dislike about my rig.
Well I ended up getting some new lights. KC Daylighter LED's. These definitely punch out further than my Auxbeam lightbar. Gonna head out at night and adjust them later. Along with them I relocated my winch control to the center of the bumper. Now it finally looks right lol.
Have had a long love of going off the beaten path and exploring where gravel roads lead , built and help build many rigs over the years but hoping this rig is here for a long while
Username: - smileyshaun
Xterra's Nickname: silver fox
Make:Nissan
Year:2011
Model:xterra
Trim:pro 4x
Color:Silver...
Intro Comments: Hello Everyone, I just got my Xterra on 12-9-2017 with 86k miles. It's completely stock right now. I'm going to change the radiator with an aftermarket one to prevent the SMOD issue. Eventually I will start offroading, but I'm new to this world so I don't even know where to...
Intro Comments: I plan to make it a decent overland vehicle. My next-door neighbor has a sweet LR Defender 90 and I'd like to be able to keep up with him. I'm more interested in getting to unique places than taking the most difficult path to them.
Username: samuel313
Comments: I bought the...
Item | Info
Make | Nissan
Year | 2005
Model | Xterra
Trim | Off Road
Color | Knights Armor
Mod List | Oblio's "The Manatee"
Username: Oblio
Xterra's Nickname: The Manatee
Year: 2005
Trim: Off Road
Color: Nights Armor
Suspension & Tires:
2in Suspension...
