1 - 20 of 81 Posts
· on line
Any damage on the front passenger door. Im looking to replace mine a few months down the road from now. I really only need the metal shell of it to replace mine which is pretty banged up.
· Registered
I need the clockspring if you can get it. Also known as the spiral cable or steering angle sensor. Have you ever dealt with one and the need to immobilize it so it isn't ruined? Also if you can check the condition of the plugs. I see the airbag is off and sometimes people jsut break the plugs.
· Registered
Serious Frame Damage from Rear Ender on X with Hitch + More Wrecked Xs added ...
I would imagine they did. Survival space was barely compromised. Hit looks low so most of the crash energy was dispersed through the frame.
Chrysler's LX cars are really safe so they should have been fine too as long as they wore their seat belts.
I saw a new 200 rental rear end a Durango so hard that the Durango ended upside down in a ditch.
The 200 front end was completely demolished from the A pillars fwd but the rest of the car was completely intact. Her door opened fine. Stupid bitch was texting on the jersey turnpike and never hit the brakes. Of course she was completely fine.
· Registered
Do any of the Nissans have the wiring in the doors for heated mirrors? Would not mind the harness end that plugs into the wiring for these mirrors along with the power mirror switch with the wiring clip attached. I can then run the wiring between the switch and mirror easily and have them so they can still be unplugged. If there is not a mirror switch with heat, that is fine, I will just get a controller for after market defrosters for the heated part and the mirror switch for moving the mirrors.
If you can't find them, I will still appreciate that you took the time to look.
· Registered
Do any of those 2nd Gens have transmissions in them still?
2005 S 4x4
2007 S 4x2 This one used to be white and had been color changed to something similar to granite. Who ever did the work did a decent job.
2008 Frontier
2006 Pathfinder
Got green?
2000 This one is a little odd. Looks like previous owner had just Plasti-dipped the trim on this one. They either took it for a drive before removing the masking or it was hit while parked. Yellow X in the background.
Mineral blue 2001 Don’t see many of these on the road. 2000 next to it.
2004
Other Nissans
Murano, Jaws of life were used to cut the B pillar off. The put it along with the attached back door through the windshield.
2005 350Z
· Registered
Man I wish we had a JY like that around here. All the JY here have vehicles about 20 years or older. Well, Japanese vehicles that is. A lot of newer domestics. There are a few yards that have newer models but they are not pick n pull style. They charge close to new dealer MSRP for used parts too!
· Premium Member
2 of the 3 Pathfinders might have them. I do know they had a different plug on the back of the mirror switch than the Xterra.
Just more curious than anything because I don't think it would be possible/worth it to ship, but could you ever get a m226?
Is that a 4x4 axle or the 4x4 axle with locker? So far I have only seen 2 4x4 Xs none were OffRoad models.
1 - 20 of 81 Posts
