1 - 1 of 1 Posts
2014 Nissan Xterra X
Good Evening Everyone,
I'm here for a likely very common question. I'm setting up my Xterra with a secondary fuse box following XJ-Xterra's How-to.
Link "HERE"
My question is directly related to the post #11 where he taps into the existing backup signal and headlight signal circuits (IPDM-51/IPDM-37 respectively).
He does not say what amp fuse he used in the line going to the relay to activate it.
I've looked up that the coil on 40a 5pin Bosch relays only draw 150-250maH or so the internet said.
I have a 1amp fuse in each line coming from the backup and headlight signal circuits.
These should blow before the IPDM fuses correct?
1 - 1 of 1 Posts
