1 - 6 of 6 Posts
· Registered
2011 Metallic Green Xterra Pro 4X
I have been getting a check engine light recently. P0420 is the error code most of the time as well as a P0101 sometimes. It didn't start happening until I moved to the mountains. Living at 9200' .
I attached some readings while driving. Constant speeds, coasting , accelerating, etc...
Before I go into the shop, I'd like to try and figure this out.
Sent from my Pixel 5a using Tapatalk
Font Electronic device Multimedia Screenshot Software
Cold
Font Line Slope Rectangle Parallel
Downhill Coast
Colorfulness Font Rectangle Line Slope
Accelerating
Black Rectangle Font Line Slope
Normal driving
Font Slope Line Rectangle Parallel
Rectangle Font Slope Parallel Pattern
Font Line Pattern Technology Parallel
· Registered
Normally I would say P0420 is cats, but your have a MAF sensor error also and your fuel trims are super high.
Clean Your MAF sensor and do the ECU relearn. Also, check the two flex hoses on the air intake - there known to crack which would give you a huge vacuum leak.
If that doesn't correct your fuel trims - replace your MAF sensor
· Registered
I have already tried cleaning and replaced the MAF. I have also checked for leaks doing the spray test. O2 sensors are new as well, but I've heard of them being faulty off the get go. My main concern was the volatility in the B1 O2 downstream. I seems a bit up and down. B2 O2 downstream is gradual like I'd expect. What should I be seeing in the air/fuel ratios?
· Registered
OK, so I see those are actual Air/fuel ratio's - I thought those were your trims as I am used to seeing that as a lambda value where perfect is 1.0. However A/F ratio perfect at 14.7:1 so yours do seem pretty good.
I would double check your long term fuel trims if your reader can - they should be approximately +/- 5%. If they are, then its likely a cat.
But I still don't know why your getting a MAF sensor code? I would figure that out before buying cats. what brand MAF sensor did you use? Was it the same with the old one?
· Registered
I went for a drive and tracked the fuel trims. long term does not seem to update. Short term seems to fluctuate with bank 1 a little more volatile than bank 2. Probably related since all the issues seem to be related to bank 1.
Colorfulness Slope Font Line Rectangle
1 - 6 of 6 Posts
