There is not. Plus the system is 4-channel only, so can only monitor 4 wheels.Anyone know if there is a TPMS in the stock spare that is already sync'd with the truck?
I am guessing there is not, but can't hurt to ask!
Thanks!
I have one in my spare as well on the Shrock - never had any problems.I know Jakedublu had a one installed in his spare(5 tire rotation) and if it bounces just right it occasionally sets off his tpms light.
The way you spell, I'm not sure you should be reprogramming anything:reserch time:
You don't have to program anything. On my Rubicon, I ran a 5 tire rotation and never had to do anything but rotate the tires.I've heard that Jeep guys can get the module to be programed from 5-4. Wonder if we could reprogram ours to handle 5 channels.
:reserch time:
That won't work. The Xterra is only able to recognize 4 sensors. Just FYI.That seems like highway robbery. You can buy 4 tpms units online for that.
I checked with 2 tire shops about adding a tpms to my spare because I rotate all 5.
One shop was $70 and the other would have been free. Neither shop had out in stock though.
That tire shop is a joke. I bought tires, carried in 4 sensors that you can buy for way less. No charge to program all 4. Just the $60 to program is total BS, you got one money hungry tire shop that need to go out of business. Those prices are probably worse then what a dealer would charge.I had a valve stem just fail. The shop that tried to change the valve stem told me the TPMS seized. Said they can order a new one from the dealer $130 + $60 labor to install it and reprogram it. For now, I have a standard stem in so at least it doesn't leak - and the TPMS warning annunciator on all the time. Quite annoying. Any suggestions?
Bummer to hear. FYI, the 2005 was the only model year with a buzzer warning noise on the TPMS. The newer model years (06+) have the warning light only.I had a valve stem just fail. The shop that tried to change the valve stem told me the TPMS seized. Said they can order a new one from the dealer $130 + $60 labor to install it and reprogram it. For now, I have a standard stem in so at least it doesn't leak - and the TPMS warning annunciator on all the time. Quite annoying. Any suggestions?
Not true. My '09 and '10 make the noise. Not every time, but some times. Not sure why sometimes and not other times. It always makes the noise when it comes on after driving on road trips for a few hrs.Bummer to hear. FYI, the 2005 was the only model year with a buzzer warning noise on the TPMS. The newer model years (06+) have the warning light only.
Luckily mine is an '06 because I don't have any TPMS on my aftermarket wheels (sold them with my stock wheels).
Well, if that is the case, I'm really glad I have an '06, because mine has never buzzed ever. I know some people with 07s that have never heard a TPMS buzzer either...maybe Nissan brought the TPMS buzzer back for '09???Not true. My '09 and '10 make the noise. Not every time, but some times. Not sure why sometimes and not other times. It always makes the noise when it comes on after driving on road trips for a few hrs.
