1 - 10 of 10 Posts
not sure if this has been discussed yet or not, but what do you guys use to clean the inside of your windows...in all my years of washing my vehicles, i have never found anything that doesnt leave streaks that you can only see at night when the lighting is just right????????
usmc xterra said:
Whatever and newspaper. MC
How about your famous Ice Wax MC? :geek:
I hate washing the inside of my windows. My arms don't bend right to do it easily.
Gotta be careful when using newspaper these days. Some newspapers have switched to using a water based ink. It'll smear and smudge your windows when it gets wet. I ususally use a glass cleaner made by any of the usual auto wax companies (whatever's on sale, just make sure it says safe for tinted glass) and Scott shop towels. Then followup with a damp chamois to remove any fuzzies left over from the towel.
Stoner's Invisible Glass and a microfiber cloth. Both items are safe if you have added window tinting. If you are also doing the outside, then make sure you use a different cloth from the one you use inside.
X2 on the newspaper ink being water soluble now. My local paper is not using it, but I have used some that has and you end up with a mess about as bad as when you started.
i use windex or generic equiv and douse the window then immediately wipe it off. I repeat this maybe one more time depending upon what is on the glass (kids finger prints etc take two wipe downs...)
make sure you use a good amount of windex and don't keep using the same papertowl. I use probably 3 towels per window.. Go through most of a roll after one cleaning event per car...
1 - 10 of 10 Posts
