Figured I would review this since I pined for it for so long...
Product: Indeflate Four Hose Unit + Quick Coupler
Cost: $200
Rating: 8/10
Link: Indeflate Four Hose Unit - The World's Easiest Way To Air Up and Down
After meeting up with @PhullD in Moab and seeing his 4-tire simultaneous inflation setup, I got pretty jealous. He had it custom made locally. Much later, I found this South African company Indeflate was selling pre-made kits. They sell a 2-tire and a 4-tire setup. Basically, what it allows you to do is connect all 4 (or 2) tires at once so you can simultaneously inflate or deflate them. This also equalizes the pressure between all tires connected. With that last fact, you can do cool stuff like "inflate" a flat tire from a full tire in the event that you don't have your air compressor or something.
The site above unfortunately I think is the only importer of the product (made in South Africa). So when I found it, it was out of stock. I took over 2 months to come back into stock. I bought it the second it became available and it looks like it is out of stock again. The "quick coupler" is needed because the indeflate air chuck doesn't have a quick connect. It's just your regular valve-stem attachment or whatever. So the "quick coupler" is essentially a quick disconnect that attaches to a valve stem.
Now that I've used it several times over the last few weeks. Here are my thoughts:
Pros:
So at this point, I would recommend it assuming you don't feel too bad about dropping $200 and assuming that everything holds up for many years.
Now while my tires are inflating, I have more time to relax and enjoy views like this!
Cost: $200
Rating: 8/10
Pros:
- Equalizes all tire pressures across the board
- Once you figure out how to unpack/repack, it doesn't really feel like any more setup/breakdown work than using a single inflator and hose or deflator
- Super flexible hose, tough quality connections, absolutely no leaking
- PSI gauge seems to be accurate WHILE air is flowing!
- No lever or trigger to hold - just plug it in and let it work
- (totally unplanned) the company colors match my Xterra
- Kind of pricey - I can get a decent quality hose, air chuck, and valve stem puller-style deflator for about $60-$90 total
- Learning curve on the uncoiling and re-packing
- Hooking up inflator right to air compressor gets hot when you try to remove it afterwards. I bought a 2 foot hose extension to separate the two
- I haven't had to use this in the mud yet - but I can only imagine trying to deal with it after it has been on the dirty, wet ground
