1 - 20 of 152 Posts
TNX Veteran
Intro Comments: I'll start this off with a big thanks to my good friend and wheeling partner @maXTERRA (Dave) for all his help, guidance, and work.:notworthy: A major thanks to Bryce Knapton, a local mechanic who's friendship and help has been invaluable :eek:ccasion5:, and to the rest of you who have answered many, many questions and done the R&D to figure all this stuff out for those of us who came later.:study:
Username: IM1RU
Xterra Nickname: "The Girlfriend” aka Delicate Flower
Trim: Pro-4X
Year: 2011
Color: Brilliant Silver
Photo by maXTERRA
I've been very bad at documenting any of this process and too damn lazy to bother with a build thread, but I have now been asked to put this together, so here it is.
ShrockWorks - Front Bumper, Skids, Rock Rails
MaxGear – Rear Bumper with Swing out Tire Carrier and Jerry Can Holder and new Ax/ Shovel ad on mount.
Boulder Ironworx – Shock Skids
ARB – Differential Cover
PRG - U-Bolt Flip Kit with Bash Plates
Cobra 75WXST CB
Tekonsha Voyager Brake Contoler
Whistler 200 W Power Inverter
Nissan All Weather Floor Mats
Fire Extinguisher in DS and PS Door
Garmin Nuvi 2789 7" touch screen GPS
Suction Cup Ram Mount for Bully Dog
MaxGear Rear Cargo Rack with dual OBA Mounts
Viair Dual 444C OBA System
Switch Pros Lighting Control Module
Offroad Gorilla Hood Rod Mod
Diamond K-400 Antenna Mount
3’ Red Firestik Antenna
Raingler Factory Rack Handles (Delete)
Stickers!
Mud Flaps Removed
Desert Pin Stripping :wink:
Semi Tire Quarter Panel Mod :angry5:
McMaster Carr 150# Rear Hatch Struts
MaxGear Roof Rack (Thanks Dave!)
Air Flow Snorkel
MaxGear custom Front Fender Trim
Poison Spider Hood Louvre
Suspension, Brakes and Tires:
285-75-16 Goodyear Wrangler Duratrac Load E
Stock P4X Wheels with Matching Spare
Extended T Swap Stainless Steel Brake Lines
RayBestos Rotors with EHT and Shoes
Radflow T-Swap Length 2.5” Remote Res Coilovers with 13" 650 lb Icon Springs
1” Top Plate Spacers
SPC Titan UCA’s with Greasable Ball Joints
Titan Moog Tie Rods
Mevotec Titan LCA's with greasable Lower Ball Joints
Nisstec Cam Bolts
Fox Remote Res Shocks Rear
Alcan 4" Lift 900 lb over stock Leaf Springs
PRG Adjustable Shackles
Timbren Bump Stops Front and Rear
Sway Bars Removed
Poly Performance Dual 12" Limit Straps on LCA's
2" Rear Wheel Spacers
Powertrain and Driveline:
Odessey 35-PC1400 Battery with new Cable Terminals
Tom Woods Custom Double Cardan Drive Shaft
Rugged Rocks 4.10 Gears
Rugged Rocks R180 Titan length CV Axles (with trail spare)
CVJ Axle CV Boots
Bully Dog Tuner – Premium Tune, WOT Restriction Off
Rear Diff Breather Extension
Front Diff Breather Filter
Evap Canister Filter Extension
Recovery Gear:
Warn M8000 Winch with Remote
Warn Cast Fairlead for Steel Cable
Factor 55 Flat Link
Ax, Shovel, Crowbar
Viair 440P Portable Compressor
48” Hi-Lift Extreme Jack
Off Road Base
Hi -Lift Lift Mate Wheel Adapter
Hi-Lift Bumper Lift
Jack Jaw Hi-Lift Rock Rail Adapter
ARB Tire Repair Kit
ARB Recovery Kit
6 Ton Bottle Jack
Tool Kit with Dewalt 20V Lithium Ion Impact Gun
Jumpstart Battery Pack
Jumper Cables
Shackles
2.5 and 5 Gal Jerry Cans
Misc. Gear and Lighting:
Tread Lightly Trasharoo
Piaa 175’s on Front Bumper (Delete)
Aurora 20" 3W LED Light Bar on Front Bumper
2 Aurora Pods mounted on MaxGear Ditch Light Brackets (hood)
40" Oz4WD Spot/Flood light Bar with Custom MaxGear Light Bar mounts
4 Kawell 6 LED pods mounted on Roof Rack Sides
20" Aurora Amber/White Combo Light Bar mounted on rear of Roof Rack
LED Reverse Lights
LED Reverse Lights In MaxGear Bumper
Red LED Running Lights in MaxGear Tire Swing Arm
8 MaxLux Rock lights
Various Spare Fluids, Parts, and Lubes
Hutch Apex 3 RTT (for those times when the Trailer just won't do)
I'm sure I've forgotten something. :tard:
And here are a few gratuitous photo's. :grin:
Link to the trailer: https://www.thenewx.org/forum/50-members-xterra/165993-im1rus-vmi-trailer-my-mistress-my-wife-calls-axle-update.html
I think we need to get the VMI up to Top of the World, back it up hanging over the ledge!
That would be something you wouldn't see anytime soon!!!!
TNX Veteran
Discussion Starter #12
You rent the helicopter and and I'm game. :grin: My luck, I'd back it right off the damn cliff.
Hey man, sweet rig! I noticed you have a pretty similar setup to what I just ordered (Extended Radflo 2.0s with 1" spacers, 600lb spring, I like softer ride). I noticed that you put extended brake lines on. Was that necessary? Were you stressing them about as far as they would go? I don't know why I didn't think about that before, but Ill be installing my setup in a few weeks and just wanted to make sure I had all the parts ready to go. Anything else you'd suggest I add? Thanks a ton.
TNX Veteran
Discussion Starter #14
Thanks!
They weren't necessary for the front, but they were for the rear, but only because the sway bars are removed. I just felt better about doing it.
TNX Veteran
Discussion Starter #15
Did some early Christmas shopping today. Bought an Airflow Snorkel and a Garmin Nuvi 2789LMT with the sunshade.
I'll update with photos after the install.
@ Brett. Basically the same rack overall. Side rails are a little wider for access to accessory mounting hardware. Side rails are heavier 12 gauge now to better support offset awning mounts. More mount holes. "X" on side rails. Accessory mounts coming soon. (Hilift and awning)
Thanks Dave - I think my whole rack is 12 gauge IIRC. Curious to see what your mounts look like too.
1 - 20 of 152 Posts
