I'm doubling up on questions today!
First one, I'm looking into getting red led dome lights to replace all the interior lighting in my X. Have any of you done red lights, if so between the various types of leds what did you buy and do you like them? I had a friend who did red bulbs in his acura and I thought they were nice but fairly dim, I hear red is usually darker than other colors and since I'm cheap I only want to buy once if I can help it.
Second question.
I'm slowly talking myself into getting some sliders that would require drilling to mount correctly. Honestly I'd use them more as steps to get into the X than anything else I can think of right now, but I'd rather be prepared then not..plus they'll look cool cruising the mall
My question is, if I drill holes in the frame should I coat the now exposed metal with something to prevent rust, if so, what should I use?
tl;dr if you have red interior lighting what leds did you get and do you like them. Should you coat drilled holes to prevent rust, if so using what?
Second question.
