1 - 2 of 2 Posts
Here's the how to on resetting the airbag light. This usually comes on anytime after you do any kind of work on your stereo, i.e. install amp, upgrade headunit, etc.
armandov99 said:
1. Put the key in the ignition, and turn to ON...it will turn on for around 6 seconds (give or take).
2. As soon as it starts to blink, turn the key off and take it out of the ignition.
3. Repeat 3 times
4. On the last time (4th all in all) it should turn on once you turn the key to ON (as it did the last 3 times) but then it should turn off and stay off. Sometimes I start the truck on this 4th time and that has worked for me as well.
hey thanks for the thread i recently installed a double dim and when putting everything back i noticed the air bag indicator... just did it and went away thanks again and by the way i just registered to make sure i expressed my gratitude.
1 - 2 of 2 Posts
