I can't say that I did this by myself because before thenewx.org went down a couple of weeks ago, it had the post on how to make this quick fix, but only had one pic. I did the mod this morning with great success. There is what I got... and steps
1. 2 feet of heater tubing and one set of heavy duty zip ties
2. Cut the tubing in about 3 -4 inch sections, then cut down the middle
3. I left the wheels on so it was a little bit more difficult, but this whole process took about 30 minutes. The best way is to bring the tubing up from the bottom so the tubing can wrap around the bottom (where the contact is.
4. now just run the zip ties up, and make sure you pull like hell on those (that's why I reccommend the heavy duty ones).
This is what I ended up with
I have to say I am VERY impressed. I went over some notorious areas that I knew I had the UCA contact before...now NOTHING. Not a bad solution for around $10 from Lowes
