Alright, I'm at work right now, so pictures will have to come later. However, the writing can be done now.
1. Remove grill. There are 6 clips on the top that are exposed when opening the hood. Pop those out then pull off the grill....there are 4 springy thingies on the bottom that will just pull out.
2. Now, if you want them where I have them, then go to the outer indentions that are on the grill...there are 4. Drill straight through towards the top of the indention.
3. Drill a hole just big enough for whatever size light you have..you want to be able to thread the light into it, so a little small won't hurt.
4. Now, the screw is not long enough to go through right?
Wrong...
there is a back to the grill....now we take a hole saw and drill about a 2 inch diameter hole inthe back of the grill (this will give us room to use a socket wrench).
5. Put on lights and screm them on tight!
6. Wire them up. Hella has pretty good directions. I will say that if you want to turn them on when you have the headlights on, then splice to the pink wire. If you want to turn them on with the highbeams, then use the green wire.
That's all!
I'll post pictures of each step tonight.
Wrong...
That's all!
