:compress: OK it's finally done. This may not be the answer to everyone's needs but was exactly what I needed.
Advantages:
Another place to throw stuff on your Roof.
It's ridiculously strong... I'm 175lbs. and completely comfortable standing in it.
Endless possibilties for bolting on accessories... Drill holes for anything, Light Tabs, Hi-lift, Shovel, Axe Mount, etc.
You retain Front Factory Basket with easy access to Rear Handle.
Overhead clearance
Lightweight... about 30lbs.
Disadvantages:
Will not fit a Spare Tire.
Cannot retain Stock Crossbars.
The Fab Build:
With the exception of the Welding this is a pretty simple build. I did all the fab in about a total of 2-1/2hrs minus paint time.
I used all 1/8" 6061 Aluminum so it's strong as a freakin Mack Truck.
Materials for Basket:
1-1/2"x25' Alum Angle
1"x25' Alum Angle
3/4"x21' Alum Square Tube
Material for Brackets:
1/8"x1"x3' Steel Bar
(4) 3/8"x4" Grade 5 Bolts
(4) 3/8" Grade 5 Nuts/Washers
(4) 1-1/2"Lx5/8" Alum Pipe for Bolt Sleeves
(1) Roll Double Sided Adhesive
Fab Cost:
Total Material: $97
Welding Labor: $80
Grand Total: $177 -- I'm pretty sure that's considerably less than a Loaded Warrior!
Edit: OK, got the Dimensions: 44-1/2"L x 32-5/16"W x 4"H
Depth is only about 3-1/16" due to Floor Height
The Brackets were the only thing I may have done different; in the process of bolting everything up I was thinking of ten other ways I could've made them, but trust me these are going nowhere. I measured them out to around 7-8" then hammered in the bend... No real science to it... After I drilled the holes everything lined up almost spot on so I was kinda lucky.
If you can't tell from the pics it sticks up about 3/4" above the Side Rails.
Getting started:
Mock-up:
Back from the Welder:
Resting neatly along Side Rail:
Handle clearance... You can see it better in the shadow:
Thanks for all the positive feedback guys!
Advantages:
Overhead clearance
Disadvantages:
The Fab Build:
1"x25' Alum Angle
Fab Cost:
Total Material: $97
Welding Labor: $80
Getting started:
Mock-up:
