Below are the details for a locking handle on the roof bin. The install is simple and takes less than 15 minutes.
The correct locking handle is the Southco 92-41-511. This is the clockwise rotating, .63-.75 grip range handle.
I got mine from Austin Hardware. It cost me $27 + $11 shipping. I got in in about 3 weeks from the time of ordering (it was backordered). The installation instructions are below.
Grip Range: http://www.southco.com/resources/literature/2-1-1.en.pdf This PDF file shows what the grip range means. Witht he Xterra latch this is not important as you use the spacer and nut that comes on the factory handle.
Clockwise -vs- Counter Clockwise: This is the direction to latch. Since the X's handle counter clockwise to open and clockwise to close, you want a clockwise handle.
Install Instructions:
Tools Needed: 7mm & 17mm socket or wrench
1. Remove nut and lock washer from handle.
2. Remove handle from lid by removing the two small screws on each side.
3. Remove nut and spacer from old handle.
4. Place spacer and nut on new handle.
5. Attach the new handle to the lid with the two small screws you took out (or with the two that are supplied with the new handle). (I used the rubber gasket that came off the old handle instead of the cork one that came with the new handle.)
6. Attach the rods with the mounts you removed from the old handle.
7. Replace the lock washer and nut and tighten them.
What I got with the new handle:
The old handle:
What I used:
The difference in the two handles. The locking one is on th left (I was concerned that the new one was shorter, as you can see, it's identical):
Links used in this post:
http://www.southco.com/product/part.aspx?pid=11917
http://www.southco.com/glossary.aspx#G
http://www.austinhardware.com/product.asp?dept%5Fid=432&pf%5Fid=3 064&mscssid=L8Q4VGLH94NP8LV48PRQXQ3L4EA7712D
That should about cover it.
The old handle:
What I used:
