1 - 7 of 7 Posts
I know there have been a few of these, but one more never hurts. This one might even be the cheapest yet (?).
Shopping list:
(2) Front fork mounts (Here are the ones I used for $10 ea: http://www.performancebike.com/shop/Profile.cfm?SKU=3702&item=00-1616&slitrk=search&slisearch=true )
(1) 40" long 2x6
(2) M6-1.00x65 mm bolt with washers (I used larger fender washers)
(4) 1/4" lag screws with washers
Mounting:
Pretty self explanatory... I mounted the fork mounts staggered so the bikes fit a little tighter and away from the windows. Bolt position so it mounts in the cargo channel and uses the factory tie-down "channel slider" (not sure what you call it... the piece the tie downs mount to) is 2" in on each side, 1" down. I welded a piece of 1/4" rod to the top of each bolt so I could tighten/remove the whole thing without tools. Rear tires are held down with a ratchet strap thru the factory hoops in the back of the rear seats. Bikes are medium (17.5") frame Iron Horse Maverick 5.5 MTB.
Took it on a few rough roads this weekend and held up great! I like having the bikes safely stowed inside and out of the weather, and can't beat the price! I also made the rear cargo carpet... $15 at Lowes for 3'x10' sure beats $70 at the dealer; it even has a rubber-like backing... and had plenty leftover, so added some to the top of the 2x6 to make it look a little better. We had it packed with a weekends worth of camping gear, too, but will be picking up a Coleman rack shortly for our next adventures... just will make life sooo much simplier.
Looks good. I need to find someone to weld a 1/4" rod to my bolts...that's a bunch easier than breaking out the wrench every time I want to remove the bike rack.
Rob
Cool! I have two of those bike tights on the way and plan to make a rack this weekend. Mine will be more like this (I hope): http://thenewx.org/phpbb2/viewtopic.php?t=4609&highlight=bike+rack
I like the way yours turned out, especially with the staggered mounts.
It's nice to see that ingenuity beats the crap out of relying on the stealership to provide a rack for $200 or more.
Rob
If you can't find somebody local, send me $10 to cover parts and postage and I'll make you a set. Otherwise, bring the bolts into a metal shop in your area and just tell them you want a piece of the rod tacked on and I'd think they'd do it for you (especially if you could have the matl in hand when you walked in).
Yeah, staggered mounts is why I went with the 2x6. My first attempt was just thrown together quickly to get them home with a 2x4 and the mounts in line with each other. However, the ends of the handlebars were touching each other and the other ends were more-or-less touching the side windows, so that is why I wanted to stagger them. I was surprised there was enough room to do it, but worked out perfect, and now I don't have to sweat a broken side window as much.
RockyMtnX said:
Rob
Yeah...that's what I was thinking...I just need to to make the time to go to a metal shop.
Rob
1 - 7 of 7 Posts
