1 - 15 of 15 Posts
Alright, finally finished the install today.
Hella 500s, 4 in the Air Dam
I went this route because i did not want the lights sitting up too much higher then the roof line, i tend to frequent parking garages and such.
The advantage of installing in the air dam is you can mount the lights a little higher or lower, or a mix, lol.
ok, to the install!!
So the air dam was removed, the four hex bolt along the bottom edge were undone and the top is held in by clips so it pops right out.
The air dam is a little flimsy so i just a 24" piece of galvanized steel to mount behind it to bolt the lights into.
Next i marked the location for each light along the metal, they were spaced out with the exact same increment between them (can't remember at this time because i did this mid last week) i also marked the locations for the nut and bolt i used to hold the metal to the air dam (before the lights were mounted.
and the two end bolt were drilled and bolted in. the steel is very easy to drill through, a regular drill bit and cordless drill worked fine for me.
i justed these black plastic caps the flip down and click into place to hide the exposed bolt. they work quite well
and one from the back
next up the drilling and mounting for the light brackets. again i just used a really big drill bit to make a big enough hole for the bolts. i used a corded drill for this part because my cordless died and the other drill is much more powerful
and this is how it looks with the lights bolted into the mounts
next was the actual install into the roof
i chose to drill through the roof close to the bar on the roof (right over the driver's head), no particular reason, just looked like a good spot.
next was consealing the wires from the lights in some wire loom....yes i used red electical tape on a black loom...only because i did not have any black tape it was getting to be 9:30 at night (notice it's kinda dark out, i had to work by flashlight because my garage is in no shape to house a vehicle....besides the old mustang the resides there...)
anyways, i put some loom from each light them combined the lights that went to the same harness....note....in this image i had the two together, but i later moved these two so one was on each end and the other two were in the middle
ok, now i drilled yet another hole in the roof and used a bolt here to mount the grounds from the lights. i had enough wires running through the vehicle at this point so i decided the roof was the best place to ground
and to cover all the exposed bolts and holes so there are no leaks....aquarium silicon!!!!....a little i had left over for a tank i made a few years back (my other expensive hobby)
so the i drilled semi-circles into the back of the air dam for the wire to run into, i also had to shave some plastic off the front lip on the basket cover because when the cover was closed it pushed the air dam up slightly
so the remaining wires were run into the roof and down the A-pillar to the underside of the dash. i did not include wiring information in the write up because i think the instructions included with the lights was pretty good, i will mention i ran the red wires from the battery +, blue from the battery -, and green to the driver side turn signal (green goes into the cabin and plugs into the toggles switch and yellow goes from the toggle switch to the harness. all harnesses were mounted in the engine bay against the firewall (wires were not long enough to reach into the grommet on the driver side from the battery or i would have put them under the dash...and i did not have the correct size wire laying around to extend them)
and here's the end result from last week, lights are now wired and work perfectly, i can take a pic of them on later tonight if anyone want to see them....oh, and i mounted the toggles by the mirror adjusters
i think i was the first person to put the lights in the air dam, i think they look pretty good here (kinda resembles a jeep liberty a little which i do not like, but i think that's because i mounted the lights too close to eachother) if i were to redo this install i would mount the lights farther apart.
hope this helps anyone considering this install!!
Great writeup!! Makes me think about it myself. I have to park in a ramp every day at work, and have about 4"-6" clearance for my Yakima X-towers. It looks like those lights would clear.
just took some measurements for you guys
the brackets for my lights at 6 1/4" from the bottom of the air dam, the lights reach 4 1/2" taller then the basket cover.
so on a stock suspension X with almost worn out stock tires i stand 79.4" at the highest point, that just under 6 ft 8 inches....still able to clear all the parking garages i've seen!!
Those who are planning on doing this mod and using KC Daylighters beware. I found out the hard way when trying to mount a set of KC's in my stock grill that the angle adjustment on them is setup to only angle downward. You can angle them up but no much at all. They would be fine if installing them on the top, flat part of the air dam or lid of the wet storage box, but when mounting them on a downward slope, adjustment may be give you trouble.
What I did to fix the problem was ground off the rivots holding the mount to the fog light housing and spun it around completely. Then I drilled new holes in the light (the old ones won't line up) and bolted it back together.
You can see the full write up and all that jazz here.
http://www.thenewx.org/phpbb2/viewtopic.php?t=8692
my radiator skid plate came loose on a trip and when i went over some mud/rocks it was ripped off completely...... the plastic bumper is attached to the same brakets so get some lock-tight just to avoid what happened to me....
Nice Ed. Are those 9" pro comp bio lights you have on your X air dam? Would you go with different metal back behind the air dam if you did it over again? How about drilling into the X's roof? Did you access the headliner by pulling out the plastic a frame on the passenger side or driver side?
Thanks for any information.
Is there a Part II? Where you show how you ran the lines into the vehicle and how you hooked them up to a power source?
Sorry, I'm not that Tech Saavy. lol
Hella NICE!!! This project is me; next.
But, how's the lights holding up with you running 60 on the freeway or even at city - vibration and the likes?
But, still my next DIY:)
Great writeup, willgr1 (yeah were are them pics?) and thanks for them pics of yours S_e_Xterra - nice mod you did!
Just so you know the last post was almost 4 years ago and the first one was over 5.
1 - 15 of 15 Posts
