1 - 17 of 17 Posts
So it looks like I am going to need to replace my axle assembly. How do I determine what rear axle gear ratio is on my vehicle. Its a 2008 SE 4x4 auto.
Thanks. That's what I thought but the mechanic that looked at it said I had 3.69 gears. But from what I found that would go to a vehicle with MT. Since I need to replace it any reason I should change to another gear ratio.
Veteran - AKA Truffle's
Wait so the c200 did come in a another ratio other than 3.13? 3.54
More than that,
XE KC 4x2 5M C200 4.083
XE KC 4x2 5A C200 3.692
SE KC 4x2 6M M226 3.538
SE KC 4x2 5A C200 3.133
SE KC 4x4 6M M226 3.538
SE KC 4x4 5A C200 3.133
SE CC 4x2 6M M226 3.538
SE CC 4x2 5A C200 3.133
SE CC 4x4 6M M226 3.692
SE CC 4x4 5A C200 3.357
NISMO KC 4x2 5A M226 3.133
NISMO KC 4x4 6M M226 3.692
NISMO KC 4x4 5A M226 3.357
NISMO CC 4x2 5A M226 3.131
NISMO CC 4x4 5A M226 3.357
LE KC 4x2 5A C200 2.937
LE KC 4x4 5A C200 3.133
LE CC 4x2 5A C200 3.133
LE CC 4x4 5A C200 3.35
3.69 only came in the m226 axle in MT, the c200 MT was 3.54. They are wrong, or you have a different axle swapped under your rig. The M226 has 12 bolts and looks like a d44 shape and the c200 has 8 and is symmetrical unlike the m226. Someone chime in here...
The Manual transmission did not and does not come with a C200 axle. The MT that came with 3:69 was the Offroad/Pro4X. The NON offroads STILL have M226 axles under them, they are just 3:54 instead of 3:69.
Yes, the frontier has others.
Whoops, you're right. My mistake, they came with m226 w/o lockers.
I like to have folks verify their own axle codes, as occasionally we have seen some discrepancies either on identification of model; or split of ratios based on model/year. Chances are very good that it's a 3.13:1 axle ... but for 100% completeness, the number that's a part of your axle code will tie to the ratio (assuming it still has stock/factory correct gears).
The axle ratio is on one of your info tags on the door-jamb of the driver's door. It'll have two letters and two numbers, if the numbers are 31, then you're set with the 3.13:1 axle to replace it. If you want to upgrade/change ratios, there's plenty of info on that in other threads.
Discussion Starter · #15 ·
Skibum
Appreciate the info. I will definitely check the door tag when I get home. I'm pretty sure it is the 3.13. based on all I read. I bought this vehicle new so unless the factory did something weird based on the model it should be as stated.
I live in Maryland if anyone has a line on a rear axle assembly.
CA31? Either way, the 31 corresponds to the 3.13:1 ratio, like folks said.
1 - 17 of 17 Posts
