Okay guys, Alot of pictures here so it should be a snap if you want to do this!!
This is the Battery right after I disconnected it;
This is the Positive Connections with the weird Fuse Panel thingy after I disconnected the Battery;
These pictures show how the Connections won't reach the Positive Terminal on the Battery;
I bought this 2 Guage Battery Cable at AutoZone... And only used the small part of the Cable that is shown. The rest I just threw away;
I bought another Terminal Connection at AutoZone and attached it to the small Cable that I previously cut off;
This is the Factory Battery Connection. I did this because I didn't have any extra screws and nuts hanging around. I needed the screw, (pictured here), to Connect the weird Factory Fuse Box to the newly Fabricated Terminal Connection;
And here are the rest of the pictures with everything connected;
Everything turned out okay! I took it for a test drive and seems to work fine!!!!!
