Man you must be psychic! My X goes in for its first service tomorrow and I was going to have them adjust the E-brake. If its that easy I'll do it myself. Thanks!
Doh! Just curious how much adjustment is there. I probably have 2.5 inches of thread showing.muzikman said:Good write up.
And once you run out of adjustment because your GF keeps driving with the ebrake on...buy new e-brake pads (this is my next thing to do).
Cup holder removalkokopop said:Sorry no pictures.
Tools:
10mm box wrench or deep socket
Steps:
1 - Remove the cup holder by pulling is straight up.
2 - Towards the passenger side you will see the cable attached to the e-brake assembly with a nut on a long threaded bolt.
3 - With the E-brake down give a few turns on the nut with the 10mm wrench.
4 - Pull back the E-brake to make sure it is tight.
5 - Re-install the cup holder.
Good to go.
Just be careful not to over tighten the E-brake. Mine was extremely loose. One a slight hill with X in neutral it would roll.
Enjoy!
Whats the black box?muzikman said:This is as far as the nut adjusts.
Sometimes I think they write that in the SM to keep people going to the dealer for small things. I'd just about bet the dealer don't follow that procedure. Ask to see the force meter. They might show you a large fish scale?kokopop said:awesome.
Thanks.
After I posted I read the service manual. Apparently you should take the rear wheels off. Pull he E-brake handle with 110 lbs of force 10 x, then adjust. Then push the level down and make sure the shoe is not catching on when the rear wheels are turned.
