Oh... I forgot to add: don't forget to adjust the switch above the clutch pedal or you cruise control will cut out at random times.
I had the same issue, and found I had to life the pedal back with my foot. My work around was to adjust the sensor, but unlike what I've read here (or remember reading), I took the sensor out, removed the jam nut, threaded the sensor back in, and put the jam nut on the other side. This allowed for the sensor to be pushed further forward to take up the slop while also using the sensor to take up that slop (i.e. it prevents the pedal from retracting as far as before). Just be careful that you don't thread the sensor in too far and inadvertently depress the clutch.I adjusted the clutch using the op's method last year, the only negative I have experienced is that the clutch pedal does not always spring back up to the end stop point. When it does this, the cruise control will not engage. My only fix for this has been to make sure I check that the pedal is fully lifted with the top of my foot.
Anyone else have this specific experience and have an easy solution?
by "sensor" you mean the "clutch switch" right???? thanks!Thanks to everyone for this information. Just did this with my 2010 (new to me) this past weekend. I ended up at 1.5 turns of the clevis and am very happy with the results.
Based on the work done here, there shouldn't be any concern over the clutch dragging unless you over adjust the sensor like I mentioned above (I know, I know - as confirmed by others with many miles on the mod). But from a mechanical stand point, adjusting the clevis length doesn't actually impact the position of the shaft in the master cylinder. No worries.
Thanks for the information, Todd!
You might want to bleed your clutch fluid also make sure you don't have moisture or air in the line.Gonna be adjusting mine soon now that I have seen this at times I wonder if my pressure plate is dragging slightly as sometimes going into gear from a stop is a little stiff or a slight grinding especially reverse
