As with all mods on here, I take no responsibility for what happens to you or your vehicle when modifying it. Do so at your own risk.
There is some mod on here about messing with the fuses which won't let you shift out of 4x4 or something and another one that requires you modify the ABS motor by either pulling that fuse, or bypassing it and connecting the fuse to a switch.
For this method, just pop the drink holder molding off. At the back, towards the center console there is a plug right there (the plug on the top of the image with 4 wires) , that is your ABS plug.
Unplug that and you are done! You can shift to 4 hi, 4 low and lock it with the e-locker no problem. To turn it back on, plug it back in and turn off your engine and restart. The ABS will be back to normal.
If you want to use a switch:
The brown wire is the ground for the plug.
Pull that sucker out of the wiring harness, snip it and connect the wires to a switch. With the switch in the "on" position there is a connection and the ABS works normal, in the "off" position the circuit is broken and the ABS shuts off. Even a momentary switch will interrupt the ABS and keep it off until restart. You no longer have to pop off the molding or anything, just hit the switch. You can now turn off your ABS on the fly and turn it back on easily upon restart! :cheers:
To use a rocker push switch:
ABS Off button installed with the use of a 5 pin relay if you want a push button similar to stock like I did. Using a 5 pin relay, 86 is the signal wire from the ABS Off switch, 85 is ground, 30 goes to the part of the brown ground wire from the ABS harness towards the front of the vehicle, 87a goes to the portion towards the rear, and 87 is not used. The 30-87a is normally on, a signal triggers the 5 pin relay and interrupts it switching to 30-87 but 87 is not connected to the ABS ground.
interesting!! very awesome find! So...when ya unplug it, do you have to have engine off? Or can you unplug it while the engine is on? If so...do you have to turn it off then back on?
Yep should be no problem to pull it with the engine running.
I have not made a switch yet due to the cold weather and lack of a garage. I did however unplug it with the engine on and it was fine. After 20 min of enjoying no ABS in the snow, I drove home, plugged it back in and did the restart with no issues.
niiiiiice! Thx for sharing! Been forgetting to do the ABS mod, but now...this is just plain easy! Got a switch laying around I can use too! just....gotta pull the dash all apart.....again....to install it :-\
You can also do it with a smaller switch, similar to the one I have done for the interior floor LED's tucked in where my E-brake is. You can get them real cheap and save the rocker switch for something more important.
Thanks for this. I had looked at the other mods, but wasn't too keen on some of the jiggery-pokery required. As it happens, I'm on vacation this week, so it's the perfect time to try this.
So FINALLY got around to doing this & running a switch for it. Yup...works 100% flawlessly!
I cut the brown wire in the loom & attached the switch "inline" with it.
I found a flush push-button switch on Amazon. Push/Depress it (& the button sinks down about 1/8"), and the ground gets disconnected, thereby disabling ABS.
So..turns out it's not a simple press on the top to get it to release. There's a locking latch on top AND bottom. Pic shows the top...identical locking latch on the bottom of it.
gotta push the very end of each latch w/ the tip of your thumb to get it to release.
Only way I was able to do it was to lift the ENTIRE back end of the arm rest console (gotta remove the two screws in the rear bottom sides ;-) ), and I had to use BOTH thumbs to depress the latches AND to pull the harness. kinda PITA.
FYI...the pin-out on the back of it does NOT match up w/ the pin out shown in the pictures. this is what they look like (red lines = pins)
I didn't wire up the ring light on it (I didn't want it lit up constantly as the switch would always be "on"). To wire it up so it cuts the brown wire connection, there's two ways depending on how you want the switch to operate: Button "up" (flush) - ABS functioning. Push button down to disable
- the left & right pins of the middle row are what ya wanna use.
Button "down" - ABS functioning. Push to release it to disable ABS (button flush)
- the middle pin & either the left or right pin. You'll have to do a continuity test to determine which one it is.
So does this mod eliminate the ridiculously over-sensitive ABS pulsing I get with 34" tires when I turn corners too fast?
You're basically unplugging the vehicle stability control IMU that's under there. Our trucks still use wheel speed and steering angle sensors. I'm wondering how that plays into it.
For a few years I've been dealing with my master power window switch being able to put a rear window down but not back up again and I'd have to reach back to the rear door and use that switch to get the window back up.
I know a bunch of us have run into the same problem and I looked at...
I finally had time to work on a new ABS/VDC/TCS/EBD off switch mod and while I was only trying to get the ABS to turn off (the version 3 abs-off yaw sensor disable thread didn't work for me) the results ended up being worthy of a new thread. When everything was back together and I was testing...
I recently installed a new backup camera and head unit with wireless CarPlay about a week ago in my 2011 Xterra PRO-4X that originally came with the Rockford Fosgate audio system with steering wheel controls and an AUX in port.
I had researched stereo installations on thenewx.org...
Hi there Peepuls.
This week on "Ballin on a Budget" I'm addressing the issue of the Evap Canister (D'Black Box from Hell) ingesting water, mud, rocks, dust, rust chips, or really anything, and failing to work, causing your check engine light to come on, and causing you to have to put fuel in...
I recently became the owner of a 2007 Xterra that did not come with factory crossbars. I have perviously been the owner of Thule and Yakima racks on other vehicles. However I decided I didn't want to buy new towers to fit to the over sized rails on the X factory rack. My solution cost about 35$...
