Considering to upgrade my battery to something better after I discovered its leaking. I found a AGM battery with 640 CCA at Orileys ( super start brand).
I also just got a Warn 10-S Evo
I know Warn recommends CCA 650 per 12,000 lbs. Do you generally want to exceed the minimum requirement? I know the battery I found falls short 10 CCA. Just wondering if I should consider a Optima or something?
Per Warn for the 10-S Evo
MAX AMP DRAW/ LINE PULL358 Amps/10,000 lbs.
Warn Truck Winches, Jeep Winches, and SUV Winches | WARN Industries
If you’re looking for truck winches, SUV winches, or winches for Jeeps, WARN has what you need to gear up and get out.
www.warn.com
