1 - 10 of 10 Posts
anyone know? Im dieing over here...or at least my thumbs are...or is there a trick? Soak them in warm water, dip them in oil...
OUCH
Greg
Intake manifold spacer's, you have to put new gaskets into it...it is a pain in the ass.
I assume they are just paper gaskets?
You can't put them over some bolts to line them up? How about a thin piece of masking tape to hold it in place?
I have never installed a manifold spacer, so I'll be honest, I am not sure, but I can't say I have ever had problems installing gaskets. That includes everything from oil pan, head, water pump, valve covers, etc.
na, they push into a groove. No big deal, I will just keep pushing.
If I remember the spacer has some seated, round rubber gaskets that fit around the ports.
No real idea how to get them in though.
I dipped a finger in oil, then kinda rubbed the oil all over them. Then push them in, they will seat all the way down.
i used a small flathead to push them in. the most difficult part was the section that is shaped like a v. that part of the gasket didn't seem to just stay in.
1 - 10 of 10 Posts
