B REAL said:
Kal... where did u mount the ballasts? I was thinkin somewhere on the inner fender.
The only other thing is the warrenty issue...should doing this mod void any part of the warrenty?
Hey B. I mounted everything right there on the inner fender, on the driver's side it is in between the fender and my intake box and the passenger side is in between the fender and the battery. It gets tight in there. The kit from the website you are looking at is basically the same thing, but instead of those brackets I used 3m adhesive, worked fine for me that way there is no drilling. Warranty shouldn't be an issue. The HID kits are plug and play you are not modding anything. If something happened you could always disconnect everything and have halogens again. The kit should come with instructions, you will lose your brights, but for me it was worth it.
I love my HID's, they are awesome. The only thing for me was I was uneducated on them when I purchased. I had the same misconception that many do that the higher the kelvin the brighter which is incorrect. That is why I am going from 12000k to 4300k, should be here this week, I will post a vid of the lights powering up, its the coolest $hit ever.
