1 - 20 of 25 Posts
I've read every thread I could find on HID and projector lights. I still don't quite understand how to install LED headlights. Can I just replace the 9007 stock bulbs with 9007 Led's and be done? Or do I need some sort of housing to put the bulbs in? Any clarification would be great. Thanks
LEDs and HIDs are 2 completely different things. Do not use LED bulbs for your low beams. The light output is weak and does not produce the legally required amount of light to be used as a low beam bulb. If you're wanting to increase your light output from your OEM headlights, then HIDs are the way to go. There's somewhat of an argument that to install HIDs, you need to install them in a projector retrofit since our headlight beam was only designed to be used with halogen bulbs. Here's a writeup of how to install HIDs without putting them into a projector retrofit: http://www.thenewx.org/forum/showthread.php?t=26639&highlight=hid+install
What about the 9007 led headlights from lifetimeledlights.com? They list 2000 lumens for low beam and 2600 lumens for high beams. Some great install threads on club frontier.
The threads on clubfrontier explain EXACTLY how to install the led bulbs. Not sure why you are still confused. No need for new housings.
I actually found the info on CF after posting here. I'm really leaning towards ordering these. I drive a lot of out of town roads, and drive from KC to Colorado at least twice at year, usually at night. Plus my security company uses Xterras and the light improvement would be great at the lights are pretty much for 8-10 hours a night every night. Has anyone used them here?
Ah, makes sense. Try those lifetime leds out. There's a code to get them cheaper from their website, think its fish15.
I am also considering LED headlamps for my next set. The new generation led headlamps are looking pretty good, these are no longer the old smd lights.
Any idea if these work with daytime running lights, for us Canadian Xterras?
Could always rig up some LED strips or your fog lights to be DRL's. I don't think anything says it HAS to be your headlights that are DRL's... Then just remove the DRL fuse, or, re-run it to whatever you want your DRL's to be.
My "Daytime running lights":
Banned
from the FJ forums, DRL seem to work fine, people dont really notice the difference in brightness from DRL to low beam. I think that has more to do with the high beam not being much brighter than the low beam, but probably because LED care more about current than voltage. i bet that little box that is inline with the bulbs is lowering the voltage because led's dont operate on 12v
21SF:
Retrofit only way to go.
Lets see, No sick color flicker. No sick cut off line....HID ONLY way to go.
I said SICK cutoff line, those are crap. Look at all that work, how much are they?
I am assuming you are an HID fan. Yes they are nice if done properly, also not cheap.
The newest CREE LED Headlights seem to be pretty decent, and are way better than the old smd lights most are familiar with. I wonder considering how much you are bashing them if you have done a side by side comparison? Got pics of said comparison?
I would like to see the results from the OP if he/she goes through with this.
My LED lights are on their way back to Lifetime. They might put out more lumens but they didn't work very well. There is one LED on each side of the light, they beam a certain direction and bounce off the reflector for low or high beam. I had both the headlights and fog lights. Neither set was worth keeping IMO. LED lights can be awesome when the housings are developed specifically for them. Like a flashlight or the Totron lights I got from T.N.X. Those are very bright, but were designed that way from the get go. Retrofitting LED in halogen housings was a waste of money for me.
  • Like
Reactions: Midnight Raven
1 - 20 of 25 Posts
