Putting in a remote starter. Can't figure out the factory alarm wires.
The diagrams say:
Factory Alarm Arm- lt. blue (-)
Factory Alarm Disarm- white/red to gray (-)
What kind of trigger is needed to arm/disarm? Pulse, constant...
I've tried both and alarm won't disarm.
Since starting the car with the key when the factory alarm is armed will
disarm it, do I even need these wires to be hooked up with the remote
starter since essentially the car will be started "normally" with all the
necessary signals and power through the ignition and transponder bypass
module?
The diagrams say:
module?
