1 - 7 of 7 Posts
I just cut my fenders again to clear bigger tires with my Titan swap. But after cutting them i realized that i cut just higher than the bottom of my washer reservoir on the passenger side. Has anyone ever relocated the reservoir? Any suggestions?
Thanks
To the OP, be careful with a heat gun if you decide to try to re-shape the reservoir. The seams on the plastic tank are subject to leaking, so be careful not to distort them much. Mine sprung a leak this past season, and so far my "fix" with some plastic putty/glue is holding...
1 - 7 of 7 Posts
