Looking for some help on an issue I can't seem to diagnose, wondering if anyone has run into something similar. Any help or suggestions would be greatly appreciated.
2008 Nissan Xterra Offroad 6MT
Truck starts up right away, idles beautifully, no codes and no abnormal noises. AFR stays right around the commanded 14.65 on both banks.
Under load, truck misses and shows 10 AFR bank 1 and more reasonable (but still leaner than commanded) on bank 2. Only code I am getting is a P0300 random misfire, check engine light will flash when giving 'er the beans then goes away when I coast. A screenshot of an uprev data log is attached.
No vacuum leaks to be found with propane or brake clean. Vacuum reads -24ish at idle.
Parts replaced:
All sensors (and coils) that were replaced were OE Hitachi, spark plugs are NGK 93759, gaskets are OE Mahle. Only thing that was not "strictly" OE spec is the throttle body, that is a Cardone reman unit.
Modifications:
History:
Vehicle developed a misfire on cyl 1 on a road trip, tried to make it home and fried the catalytic converter. Had a family member towing it for me, they got in an accident, which smacked the front end of the Xterra. No frame damage, so I bought it back from insurance and replaced the grille, radiator support cross member, Passenger fender, hood, upgraded to ARB bumper, and upgraded to volant cold air intake (added XTP IMS at the same time). Went with long tube headers & removed primary cats at the same time as I did not want to deal with a failed cat again, which is apparently common on the VQ40DE. Inspected cylinders with a borescope while the exhaust manifolds were off and there was no apparent damage or catalytic converter residue.
Parts replaced:
- Bank 1 & Bank 2 cam sensors
- Crankshaft sensor
- All 4 O2 sensors
- MAF sensor
- Throttle body (&TPS, TPS was making a weird buzzing and would not relearn)
- All 6 plugs and coils
- Intake plenum gaskets
- Throttle body gaskets
Modifications:
- Volant Cold Air Intake
- XTP IMS
- Doug Thorley Long Tube headers
- Dynomax 19443 cat-back
- Uprev base tune (have not been able to send accurate logs over to uprev due to this issue, issue pops up whether on the base tune or stock tune just doesnt throw a code under stock tune)
History:
