1 - 4 of 4 Posts
2009 Nissan Xterra X
Passenger side
Coolant related
Was trying to reach the A/F sensor and this plastic part was crumbling and snapped. Coolant leaked everywhere... haha
Looking to indent the part so I can fix my original issue! Thanks!
132479
OEM part: 2005-2012 Nissan Pathfinder HVAC Heater Hose 92408-EA000 | Courtesy Parts
There're a few how to threads on replacing those plastic parts altogether with standard brass hose fittings.
How-to: Replace Plastic Tee in Heater Hose
Perhaps among others. Search this site for "92408-ea000".
2011 PRO-4X
No fittings are needed.
Remove the hose from the plastic fitting then the fitting from the heater core. Now connect the heater hose directly to the heater core and DONE!.
For the other one with the aluminum hose that will break also the cheapest and easiest fix is the Dorman 626-598.
Registered - From Westminster, CA, USA
I’d definitely remove that broken part and Hook straight to the heater core.
then replace the one beside it attached to the aluminum line. It’s one piece and probably $70 at the dealer.
Same thing happened to me as I was flushing my coolant so I replaced anything that looked old in the area.
1 - 4 of 4 Posts
