I'll be there the 22nd/23rd. Mark your calendar and rally the troops!!!! (I'm going to put something in the Events/Trail Runs section with a timeline of when I'll be where)
some of the frontier were talking about doin that run again , as long as its not 20 trucks like we did lat time lol , pick jeeps were not happy , especially cause a few went up devils stair case
Haha, i saw the video on You tube. The pink jeep drivers as a whole are pretty annoying. They act like they have some sort of god given right to the trail because they make money off of it. I was out there a couple of years ago, and they were directing jeeps to pull over for them, acting like they owned the land, not the Forest Service.
So I was looking again at my driveshaft/differential angle, and it looks like the shims when installed might have been too much. ie: My vibration got better, because it went to the ideal spot, and then some. It now looks like the differential angle is pointed higher than the driveshaft is coming in at. Perhaps getting a 2 degree might fix this problem, and straighten this thin out? Anybody have a problem with this happening with their 3 degree shims. I think what is happening, is for some reason my shackles are causing the angle to be tweaked slightly up, instead of having no affect.
i'll take a pic of mine for you tomorrow if you want. Also, my dates changed slightly for when I'm in Sedona (by 2 days). check the events/trail runs thread
Yeah, i have read through that thread. The problem is that my driveshaft appears to be very touch for some reason. According to both my mechanic, and Greg at PRG, the angle my driveline is at should be fine, well within range. However, like I said, the shims made the angle swing the other way.
I tried different shackle settings, and the notch down (very bottom on shackle), and the vibration 'seemed' to get a little bit better overall. The next higher setting was worse, and the top hole was the worst. Assuming that the shackle is increasing the differential angle toward the sky, this makes perfect sense.
My conclusion remains that I went past the mark I needed, and if the shims greg sent me were indeed 3 degree, then 2 should do the trick.
When I used to live in Sedona I'd stop the Pink Jeep convoys by riding in front of them on my mountain bike. Nothing like cutting off a PJ then blasting by it downhill on a bike..ruins the illusion of "danger" that they like to pawn off on their customers. lol
There is a correct direction to install the deavers. The directions provided with them tells you how to figure it out. I have the three degree shims, and i have no issues. 20k and going on the set up.
I just checked mine. The longer side is forward on both sides. Damn, I wish that was my problem, haha. If it is my pinion angle, its insanely close as it is. Not sure why it is picking on me. Does anybody happen to know their diff angle and driveshaft angle?
I would think that you might have some problems if they weren't. I checked mine...fine. I honestly wish that was it. Oh well, my 2 degree shims got here today, will be put in tomorrow. Hopefully the shimmy goes away!
Ok, there's does not seem to have been enough pictures or usefull information to the issue that was brought up. I have the Deavers, PRG shackles, and the shims that Greg sent (not real sure of the angle, 2 or 3 deg). But, I'm going to post my pictures for you guys to see. I have no driveline vibration, and had very little if any before the shackles. My order of adding was Deavers, Deavers with shim, Deaver with same shim and shackles.
1. Driveline angle with Deavers before shims.
2. Driveline angle with Deavers and PRG Shackles on center setting. A very small upward angle, but not bad at all compared to no shim.
3. Spring seperation that is only caused by the spring pads that seems to be normal.
4. Don't forget if you have a front of rear axle bumpstop, take out the bolt of the Deaver spring guide. It will hit.
Damn turtle, i thought the underside of my X was rusty! Your spring pack and skidplate look like you picked them up from the bottom of the ocean. I just finished spraying two coats of rustoleum black paint on my deaver pack. Hopefully next week ill be installing the whole PRG lift kit.
That would be from the wonderful world of northeaster Ohio road salt. And I didn't paint my gas tank skid quit well. After a spray down though most of the rust will show on the aftermarket items more that stock parts.
21 - 40 of 40 Posts
