well it snowed today we got almost 8 inches duped with a buch of ice on top and the girl has never had a 4x4 in the past...I have tried to explain it to her and I am just not gettin through...any ideas on how to simplifiy this...there needs to be a youtube vid that I can just send the link to her for her to understand....shes very smart....but when it comes to cars and trucks shes lost....
Here is how you use your pt 4WD vehicle most efficiently:
• Drive in 2WD most of the time (that's where the name "part time" is coming from - you use 4WD only part of the time)
• shift only into 4WD when you encounter snow, ice, or a rain slick road
• shift back into 2WD as soon as you encounter dry surface
• you may even want to shift back to 2WD while still on snow - because some vehicles display a binding effect even on snow.
• if you encounter turns while in 4WD just know that the steering will not be as crisp as in 2WD (understeer will occur - the turn might be a little wider than planned)
• please be aware that ABS does not work properly with part time 4WD
• More weight = more traction
