Can somebody tell me where the fuse to the heater is and what fuse I need to buy? I've checked everything but can't find the fuse, thanks
it wont blow at all, I replaced the motor fan, the card that you push up into the slot, and then today I put a new fuse into the fuse under the hood second to the front and its still not on. I hear the engine change a bit when I turn it on, but it wont blow or anything, so I am kinda stumpedHeater not working... As in the fan won't blow or it just blows cold air?
Hopefully this will help too. This is just a pic, because I am having a hard time finding the wiring diagram on Nicoclub.
This is for the Manual Temperature Control troubleshooting.
I understand it is cold, throwing parts at the X in hopes that it fixes it can get you frustrated. I hope it is just the relay now, if not take a second to read through the troubleshooting steps and make sure you are on the right path.
I will have to check everything with a wire tester, I replaced the fan motor, the fuse under the hood for "Front fan", and the relay, and still nothing. I was told it was up under the dash, and I do not see any place for a fuse to go its just wires, its literally -3 outside doing this, could one of the fuses be blown in the right side panels and I'm not seeing it? I checked, do you know which numbers they are? everybody sys to look at the diagram but it does not say which #'s the heater is, its very confusing, I do not see any place up under the dash for that fuse only one under the hood labeled "Front blower". I've spent $140 so far trying to figure it out.Have you checked for power at the fan/harness connection? If there is power there, the fan motor is toast.
Are you aware of the fuse panel next to the glove box? Open the glove box and there is an access panel maybe 3x6 to the right of the box. Pull the cover off, there about 15-20 fuses in there.I replaced the fan motor, the fuse under the hood for "Front fan", and the relay, and still nothing. I was told it was up under the dash, and I do not see any place for a fuse to go its just wires... I do not see any place up under the dash for that fuse only one under the hood labeled "Front blower".
The knob that turns the fan on and off.What do you mean fan switch?
