Well it was the air blend door motor. It honestly wasn’t tooo bad to get to considering. You just need to remove the entire dash cover. I’d say it’s a 6 beer job.
I don’t think your issue will be the same. My compressor was operating normal. The issue was that the blend door was stuck on full heat so no matter what temp I told it, it was blowing full blast heat.I hope this isn't foreshadowing the repair needed for my heater being intermittent. Mine also includes an odd behavior where the A/C compressor intermittently only turns when I rev in neutral 1600 to 1800 RPM when Idling
