1 - 4 of 4 Posts
My headlights retaining ring cracked on the passenger side. I looked on ebay and amazon for a replacement abduction count find one. From what i understand you can only get them with the headlights assembly. Does anyone anyone know where i could get one or have one laying around. Also since the x is based off the frontier could i use one from it? My x is an 06.
thanks.
Xterra has different lights then a Frontier.
Could you post a picture, I really can't figure out what ring you are referring to?
More then likely you will need a whole headlight. But without understanding what ring you are referring to it is impossible to really know.
I think he is referring to the white plastic ring that holds the headlight bulb in place against the back of the housing.
26029-0Z800 $8
26029MB in this picture
I would post a picture but i have everything siliconed into place right now. But yeah its the white ring that holds the bulb into the headlight. I haven't check junkyards yet. That might be my only option.
1 - 4 of 4 Posts
